Topic: Got a little work done today.... (Read 2560 times) previous topic - next topic
I raised the rear of the Sport and drained the differential, pulled the passenger side rear axle shaft and swapped it. I also installed the new differential girdle and cleaned the battery terminals (unrelated work in case you were wondering).. man what a difference that made. I think I need to get a dry cell battery when funds allow. No matter how much I have cleaned the terminals, the ground terminal corrodes. I cleaned them up, and this time I installed the felt pads under them, and sprayed some corrosion preventative on them. made a huge difference in the idle and overall performance. I still have to test drive the Sport to check and see if the axle shaft is better than what I pulled. We'll see. Anyway, that's the little bit of nothing I have to share today.
Dude contact corrosion just creeps up on you like no-one's business. I cant STAND that, you clean em up and "oh wow my battery and starter aren't both bad it just wasnt making a connection!!!!" Definitely save up and get an Optima red top, I think that's the biggest-baddest one they make. My friend can't believe he didn't get one for his vette long ago.
Was your rear end making noise Vinnie?  Glad you go that done.
Had a vibration around 70 to 75mph. I still haven't hit the highway yet. As far as a battery, the Optima is what I'm hoping to get.
I heard they started making optima in Mexico now and quality has gone to  (note I heard this from a guy who worked at a battery store that didnt sell them, so he might have just been biased)
I still want one.
my buddy uses nothing but optima and both his cars have HUGE systems (turbo stang has 2 15" CVX, and his honda has 4 cvx 15"s) and his work fine...so I think the guy at the battery shop might have been trying to sell me something else since I went in there specifically asking for optima.
When you do get one, let us know how it holds up.
I'll post up the results. It'll be a while. I have a lot about to happen. Body work,paint, window tinting, new rear tires. one step at a time.
What girdle did you use?  Snap a pic sometime when you get a chance.
Mike
I'll grab a pic tomorrow. It's a nice piece,and it was super cheap (new).
I think battery terminal corrosion has to do with grounds. I've never had to clean corrosion from the battery terminals on the 88 T-bird. The 95 T-bird I used to own always had battery terminal corrosion until I went around and cleaned and reattached all the grounds in the engine bay. After that I never had a problem.
I sometimes wish I had stuff to tinker with on my T-bird. At this point all I ever do is start it and drive it, which, in its own way, is kind of nice too.
It's my battery. It checks fine, but it's a  battery. I got it cheap just to get it running a long time ago and have never swapped it out. It's time to upgrade.
I've always had good luck with Motorcraft batteries in mine.
You getting the Sport repainted? I never realized it got damaged. So sorry to hear that, man. I know how you love that car. I don't look at the list every day... must have missed the news.
Hopefully the axle cured your 'bad vibe'. Some cars are harder to get the vibrations out of than others. I had a Merkur that I NEVER could get to run smooth after I did a T5 swap.  Anyway, good luck with it.
The vibration was there through the other engine, AOD, T-5,two differentials and two drive shafts. The only things that have been the same are the two axle shafts. I still haven't had a chance to really test it. I'll take her out this evening or tomorrow.
The new paint is no issue. The hail beat on the Sport a little, but that gives me a chance to do some things for the body I didn't have a chance to do before.
