Topic: problems after heater core replacement (Read 1348 times) previous topic - next topic
Ok, so my heater core sprang a leak. I printed off Eric's instructions and now that the core is changed and all back together there are a couple problems. The car won't start with the key but will start from the solenoid. Then driving down the road I noticed that the speedo is not registering. It just displays the odometer and a 0 for the speed. I never noticed if the odomenter is increasing! So, what did I eff up???
Im assuming you had to take the dash out to replace the heatercore....MY first guess is you either didnt plug everything back in tight or you broke a wire somewhere.
You were absolutely right. Plug behind the radio wasn't plugged in.
