TC hood clearance? July 31, 2011, 11:10:29 PM All you fellas that have a V8 tbird/cougar and the TurboCoupe hood...What did you do to make the hood fit? My driver's side hood scoop ishiznitting the A/C compressor bracket.Pics would be helpful with your explanation. Thanks! Quote Selected
TC hood clearance? Reply #1 – July 31, 2011, 11:37:20 PM Grind down the bracket. Or remove it. BTDT. Quote Selected
TC hood clearance? Reply #2 – July 31, 2011, 11:49:33 PM I removed the steel bracket. The 4 bolts that hold the compressor down have been more than adequate for the Sport. On the driver side scoop, I trimmed down the rear two studs leaving just enough for the nuts to attach. Quote Selected
TC hood clearance? Reply #3 – August 01, 2011, 09:28:41 AM When I had mine on my 83 5.0, the scoop baaaarely cleared, so I just left it alone. Eventually, the scoop developed hairline cracks. The bracket must raise up and hit it when the motor twists while driving. That's the only way I could figure it made contact. So yeah, I would just grind it down a little. Quote Selected
TC hood clearance? Reply #5 – August 07, 2011, 01:32:32 PM I swapped to mustang (foxbody) AC/PS brackets.. Quote Selected
TC hood clearance? Reply #6 – August 07, 2011, 02:34:24 PM I'm about to put the AC components back on my HO engine...has all the Stang accessories, and have a TC hood...will i need to grind the bracket or the screws on the one scoop? Quote Selected
TC hood clearance? Reply #7 – August 07, 2011, 03:11:15 PM I have Mustang brackets and A/C compressor. There were no clearance issues with the scoop bracket on a TC hood and the A/C bracket (the hood was just installed this past week)I did however, have a clearance issue with the bracket that mounts the Procharger. The Procharger bracket mounts to the front of the A/C bracket, which adds a 1/2" of thickness and height. This required the mounting bracket for the scoop to be trimmed 1/4". Though the bracket is thinner, both mounting holes remained intact for the scoop.So the upshot is (in my experience); if you have Mustang accessories, expect about a 1/4" of clearance between the A/C bracket and the scoop bracket (assuming the front of the car has not been tweaked). If you have a Procharger w/air, expect to get the cut off wheel out! Quote Selected
