Topic: swap questions (Read 3407 times) previous topic - next topic
swap questions
hey guys/gals! just bought a 88 t-bird 3.8 and was wondering a decent engine i can swap mine with, was thinking about a small block but i have no idea and was hoping for any advice, thank you.
swap questions
The simplest and cheapest upgrade would be the 5.0. Plentiful engines. "Cheap" is a relative term. It can cost a lot if you want it to, and requires some patience to find all the parts you need. I'd take time, shop around, hit the yards, andacquire everything you might need before you start. It does require some effort.
Fuel lines
motor mounts, harness swaps
computer
fuel pump
accessories
EFI setup.....etc.
If you go carb, that makes it a lot easier. It all depends on how deep you want to go into this project. Quite a few members have done the 5.0 swap into their 4 and 6 cyl cars.
swap questions
If I were going V-8 I would go with an engine that's not already in that model t-bird.  351 Windsor would be nice.
1987 Thunderbird Turbo Coupe (daily driver) - T5, Short Throw, Ranger roller cam (soon to be Boport 1.5), stock turbo and TMIC (also soon to change.)
swap questions
427, 428 o 429!!!
swap questions
The only engine I'd go to other than the 5.0 would be the 351W or one of the newer style 4.6 or 5.0 engines. I needs to be able to get parts easily.
swap questions
Quote from: ACCEPT;364508
427, 428 o 429!!!
I'm pretty sure a 427 or 428 FE won't fit in a Fox without major work. A 385 serries 429 or 460 bolts in pretty easily...
swap questions
do the 5.0 ho swap.relatively cheap swap with used parts. i just did one in my cougar (again) cause i spun a rod bearing
swap questions
I'd go 351w
:burnout:
