Topic: Lens on headlight (Read 1167 times) previous topic - next topic
Lens on headlight
What's the best way to remove the clear lens on the head lights? I heard baking in the oven? or just cut them with a knife.
Lens on headlight
I have scribed the glue line carefully until I can pull the lens off using an exacto knife. Other times I've been lucky enough to just pull the lens off by hand.
Lens on headlight
Sounds good to me!
Lens on headlight
Take your time Kitzy. It's easy to apply too much pressure and scratch the light up. ALSO, when using an Exacto knife, they actually scribe better if you turn the blade upside down and use the other side of the blade. Sharp side up., I learned that scribing new panel lines in model cars.
