Topic: looking for the clutch safety switch bracket (Read 727 times) previous topic - next topic
I thought i was smart by getting the switch but I left the bracket..... does anyone have the bracket so I can hook it up to my new pedals???? it looks like this
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
also what is the other plug for????
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
where is it located on the car? I'll see if I can get it from the same car I got your light sockets from
up on the left side on the clutch pedal
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Oh yikes. That might not happen unless I can get to them w/o taking the dash out...
bump
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I found one!!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
