Topic: AOD Question... (Read 1445 times) previous topic - next topic
AOD Question...
I have an AOD transmission from my 87 tbird. Another owner have driven the car with too much oil in the AOD. The front seal is leaking, is there anything else i should look for?
Vegar
AOD Question...
If it isn't slipping then you should be fine, the front pump probably just pushed the seal out from to much fluid.
AOD Question...
Thanks for the info ;)
Vegar
