Topic: Lincoln Mark VII parts of value... (Read 2874 times) previous topic - next topic
So, I've been looking through here, but I don't see much info on Lincoln Mark VII parts as to whether they can be successfully swapped to a Bird or Cat. I'm curious about the rear springs and the front and rear sway bars mostly, and how they compare to the Fox-body Mustang and Turbocoupe/XR7 options.
TC bar is bigger, as is a 5.0 Stang...not sure at all the springs can be used...do they have springs? Pretty sure they're air ride...
Front Bar is smaller than a TC  and the rear bar  wont bolt up with out modification to the car , and yes they are air ride equipped
odd... the one i saw today had springs. must be a conversion kit. i may just try them out and hope i get lucky/post results. but yeah, i had hope the sway bar would be bigger. oh well... thanks for the input.
Quote from: jncocowboyx;362674
Conversion kits were quite common on them , I personally am not a fan of the coil conversions on them .
I was looking at a Mark 7 last weekend for the brakes, axles, etc, and noticed the rear bar bolts up differently than 'Birds and Cougars....ours bolt to the lower control arms.
Quote from: ThunderbirdSport302;362684
More than likely due to the air ride suspension
FOXLESS!!
1994 Lincoln Mark VIII
I have seen a few mark VII's that came factory with coil spring suspension.  I wish I could have snagged one when I had the chance!  I'm not sure what Lincoln's method was when they furnished them with air or coils?  I do know they had the Bill Blass edition and the LSC, not sure if that mattered or not.
Quote from: beast50;364357
All mark VIIs came with air ride from the factory,  no matter the trim level . The LSC cars had a different air spring than the other models , the base was different to provide a stiffer ride .
Yeah, I was wrong.  I assumed if they had struts up front they did not have airbags. I had a 1984 Continental on a fox chassis.  It had the airbag suspension (rode awesome when they stayed inflated!) I do not remember it having shocks and struts.  I googled Mark VII's and found some cool facts!  Makes me want one!
No they all didn't come with air ride. There was a model year or two that DID have coil springs, but IIRC that was at the beginning of their existence. When I put a MKVII rear axle and front spindle/rotor setup in my car it had the coil setup under it. I checked with a friend that was (recently retired) the service/parts manager at a local Lincoln dealership about that. They weren't really that common though. They switched to the air ride setup because they wanted a smother ride..........ya ok.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
