Topic: blue smoke (Read 1967 times) previous topic - next topic
blue smoke
whenever i start my car up a cloud of blue smoke comes out of my exhaust. it keeps putting out clouds of blue smoke until the engine gets hot and then even if i rev it, no blue smoke comes out. Leaving work friday i did a little fish tail in the parking lot and when i stopped at the exit a cloud of blue smoke was all around my car. Any ideas on what this might be?
blue smoke
Usually the first thing to look at with those symptoms is valve seals , but it is really impossible to diagnose over the internet
blue smoke
thats what i was thinking. Can they be fixed without taking off the head?
blue smoke
They can be replaced without taking off the heads.  Fill the cylinders with air and remove the valve springs and retainers. Replace the seals and put it all back together. Piece of CAKE
blue smoke
lol yeah that sounds super simple!!! but thank you for your help!
blue smoke
i also have oil on all my spark plug threads.
blue smoke
1) Check the pcv system.
2) Check the intake for signs of oil. Start at the compressor outlet, if you have oil there, check that the VC breather is clean and functioning properly.
3) If pcv and VC breather are clean and working, and you have oil in the intake tract starting after the compressor, I would start to suspect the oil seal in the turbo.
4) If you don't have oil in the intake, but you're buring oil, and you have evidence of oil in the cylinders, you're looking at possibly the valve seals, or rings.
blue smoke
I had the same issues 3 engines ago...it was my valve seals....not saying that's your problem, but it may very well be.
blue smoke
Well it looks like its going to be either the valve or cylinder walls but when i had my head off my walls looked perfect. A guy from a local mustang shop said the head will most likely have to be taken the head off again and have the shop that worked on my head check it out. I went through a whole oil pan in 3 months....
blue smoke
Check the simple things before you go pulling the head off again. Find out if you're oil burning issue is PVC or turbo related before you go through the trouble of pulling the head. Also, as cheap and easy to replace as the valve seals are, I'd try those before pulling the head.
Just because your cylinder walls looked fine doesn't mean the rings aren't on the way out, but I'm not saying that's your problem.
blue smoke
it could be blow by from the oil rings onthe pistons and you burning oil but you never no if you have high milage or over filled the motor with oilare the causes of bad rings.
Cain, Pony Express Racing
Cougar on a diet to suck gas and haul ass!
blue smoke
whats the difference between a good valve seal and a bad valve seal. Im going to tear down the top part of the motor and take a look.
