Topic: Rear coil spring question (Read 2081 times) previous topic - next topic
Now that ive got my front end done, Im gonna focus on the rear.  Im looking for about 1-1.25" drop.  My plan is to use the stock springs from a 95 convertible.  It shows they are cargo coil 827, on the MOOG site.  Will those hit it about what I want? :hick:
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-CC827
Specs are at the bottom.
Mike
Nobody has used SN95 GT convert springs in the rear?
Mike
I used standard SN-95 springs in the rear and got the 1.5 inch drop I wanted. I would wonder if the convertible springs are stiffer. Maybe not as much of a drop, but I can't say for sure because I haven't used the convert. springs. The standard SN-95 springs are great.
I knew you used the standard ones, I think Ill try the convert springs.  Thank you Vinnie.
Mike
They may turn out to be a little stiffer. Not a bad thing. Post your results. Heck, they be the same. I know the V-6 and V-8 cars (coupes) shared the same springs.
I had the spec's from MOOGs site, the converts were a little higher load rate and spring rate vs. the reg SN95.
 Ill post the specifics later.
Mike
Convertible springs are heavier and normally have a higher spring rate. Convertibles are normally heavier than non convertibles. If moog shows a different number for convertibles the springs are heavier and will most likely raise the car. My choice would not be a cargo coil. They are a heavy duty spring and normally raise the car a bit. Thanks
Here is what we do and some might flame me on this practice but it increases the spring rate while lowering the car. This is the maximum amount we would ever  cut
http://i600.photobucket.com/albums/tt88/tomrenzo/Kitties244.jpg
The IRS cobras used rear springs with less spring rate and higher load rate vs. their coupe counterparts. Apparently Ford wanted a bit softer ride for the 'vert w/o loosing the height. This very well could be different for the live axle springs you are looking at, however it sounds like you have all the info on MOOGs site to figure it out.
Load rating is what will determine ride height. So if that is your main target, that is the number you will need to concentrate on. There is a specific number floating around here someplace that gives a relationship between the amount of change in load rating vs. change in ride height. I'll see if I can locate that.
Quote from: TOM Renzo;362016
I would also stay away from the cargo coils as a preference. I dont like variable rate coils if I can avoid them.
*edit: found the info
Quote from: SVOMike;128769
The rule of thumb in chassis engineering was every 150 lbs in load rate subtracted from the factory selected springs the front would lower it 1/2" in the front and every 50lbs of load rate subtracted from the rear would lower that 1/2".
I wont flame you, I do, and have done the same thing before,  I just cut my front springs 3/4ths a coil with the grinder just like that.
The cargo coil is supposedly the stock coil.  It is a progressive rate and the specs on it are much less than the stock Cougar coil, which is currently on it.  I think it will lower it about perfect for what I want??  We'll see.
Mike
The convert rear SN95 springs have 235lb less load rating, and 75lb less spring rate than the stock cougar 8599 springs.
I think (hope) it will lower it about right.  If the stock coupe SN95 springs dropped it 1.5" , Im guessing this will do what I want.
If not, I will go with reg SN95's and drop it a little more.
Just because they are CC's, doesnt mean they wont lower a Cougar, remember these cars have a thick heavy booty compared to the Stangs.:D
Mike
Spring rates and loads
5190    wire diameter  .541          convertible
          load height      10.50
          number of coils  9.38
          load                  650
          rated load height  174
          free height          13.57
5367    Wire                    .541      cobra
          LH                        9.63
          coils                      9.37
          load                      650
          rated height          174
          free length            13.57
5372      wire                .540              coupe
            LH                    11.00
            coils                  9.28
            load                  322
            rated height      162
            free height        13.00
Quote from: TOM Renzo;362030
          load height      10.50
          load                  650
          free height          13.57
Im not sure what the 5190 is, but it has a installed height 1" higher than the Stang or Cougar.
Mike
Just posting what the rates are . This is moog specks. That is a convertible spring. Its a higher spring as i suspected.
Quote from: TOM Renzo;362034
Higher vs. what?
Mike
