Topic: Front lower control arms - 87 tbird (Read 3014 times) previous topic - next topic
I have read somewhere  here that the control arms from a SN95 Mustang fits in place of our stock arms. I have found a set of arms from AJE (anthony jones engineering) that have spring cups, since i want to keep the stock style suspension and K-member. Do anyone know if it mounts right up or do i have to modify something? like the connection to the stock fox spindle....
Vegar
Yep, the SN95 CA are dimensionally identical to the '87-'88 parts....
Just use Fox ball joints, or you CAN use SN95, but you have to put a spacer under the nut, as they are a little longer.
Hope this helps
Quote from: ThunderbirdSport302;361824
Hope this helps
The Fox ball joints are longer.  You can use Fox ball joints with SN-95 spindles with a spacer, but you can't use SN-95 ball joints with Fox spindles, as they are too short.
Yep..I thought i had it backwards :hick::punchballs:
I have the SN-95 control arms on my car.
Quote from: Chuck W;361827
Didn't someone here machine down the fox spindles to run SN-95 balljoints?
Quote from: thunderjet302;361836
Yes, someone did.  You can do it if you like, I suppose.  For me, it's a lot of work for a py front brake set-up.  Even the py SN-95 brakes are better than the Fox ones.
Thanks for the info guys :)
