Topic: Is this E-Fan good enough? (Read 1991 times) previous topic - next topic
16" single fan, 2,010cfm. Will this be sufficient enough on my 5.0? I know nothing about airflow.
http://www.summitracing.com/parts/SUM-G4904/
It didnt work for me I needed one with a full shroud. Used one from a 99 cougar
With what little room there is between the radiator and block on my car, I don't see how it wouldn't work that well.
I use a Taurus fan. Very good flow, better than most aftermarket fans and the shroud fits great on our radiators.
I thought the same way and the one I used was a 2800 cfm and putting around on a 80 degree day it would run at 220 when beating the pants off it it would hit 250 and puke a 20 lbs cap not a fun fealing on a new motor
http://www.summitracing.com/parts/SUM-G4852/
This is what I'm using and it works great.  Fits right on my direct fit aluminum radiator.  I also pull the air through my intercooler with them.
I don't have time to go find a taurus fan, and the probability of someone selling one is low. I need a fan now. The fan clutch going out is aggrivating, and I want the mechanical fan gone.
I like the Volvo 740 electric fan. Its a clean 15 minute install and it works great. You can get one at any junk yard or on ebay. It comes with a complete shroud that covers the entire radiator area. Heck if it good enough to cool the big 24 valve DOHC in the huge volvo wagon, it will work for you too. Works great for me.
One in the junk yard in a 740. also can be found in some of the SOHC turbo Volvo's too
http://i158.photobucket.com/albums/t97/biggrgivens/volvob.jpg
Installed
All it took was two radiator zip tie supports at the bottom, and two of the stock screw and brackets at the top of the existing radiator. The hles in the Volvo fan actually line up with the existing Ford brackets at the top of the radiator. No bracket fabrication at all. Just slide it in place and secure it. Again its a 15 minute job.
I have one extra that someone requested to buy, so if you want one, hit me up.
I'm using one of these...
http://www.jegs.com/i/Flex-a-lite/400/185/10002/-1?parentProductId=756607
I was like you, needed it NOW! It's been working fine with A/C and an under driven high flow water pump for three yrs now BUT, since I now know better, there is a Taurus unit just waiting for me to get the time to install it.
