Topic: Rebuilding 8.8 Trac Loc (Read 3372 times) previous topic - next topic
I've got an 8.8" Trac Loc Rear end. It needs new clutches which I've only priced through eBay at $135, is this a good price? Where is the best place to buy from. Also the ring gear has a tiny, tiny chip in one of the teeth, the size of a tic tac at best. Is this something to worry about? I would like to swap this rear in after replacing clutches, and would have no problem driving it considering I'm pushing 130hp at best in my stock 5.0 with exhaust. Any help with parts is appreciated.
http://ratech.stores.yahoo.net/clpafo8ax.html
I get my 8.8 rebuild kits from them.  Quality and have never had a complaint from the guys that have installed/rebuilt the rear ends over the years.
Darren
$135 for just the clutches?? :bangford:
Try these guys.
http://www.thegearbox.org/home.html
YDGF8.8-28-1 - Yukon Dura Grip  $298.09  [21.56 Lbs]
Yukon Dura Grip positraction for Ford 8.8" with 28 spline axles
Yukon Duragrip posi for Ford 8.8" with 28 spline axles. The Yukon Duragrip uses a nodular case and forged 4320 internals for added strength along with composite clutches for high performance and long life. All units are Rebuildable and many offer upgrades to increase aggressiveness for racing applications. Each unit carries a one year warranty against defects.
Relevant Tags: YUKON GEAR, YUKON AXLE, YUKON, TRAK LOK, TRAK LOC, TRACK LOK, TRACK LOCK, TRAC LOK, TRAC LOC, POSITRACTION, POSI, MUSTANG, LIMITED SLIP, FORD 8.8, FORD, DIFFERENTIAL
[0.0] [0.0] [0.0] [0.0] [0.0]  Average Customer Rating: 0.0  (0 Reviews)
Ford 8.8 - 28 Spline Differential Posi / Positractions YDGF8.8-28-1 - Yukon Dura Grip positraction for Ford 8.8 with 28 spline axles  View More Details
Ford 8.8 - 28 Spline Differential Posi / Positractions AG 542079-HP - Auburn Gear High Performance positraction for Ford 8.8 with 28 spline axles    AG 542079-HP - Auburn Gear Posi  $499.47  [21.25 Lbs]
Auburn Gear High Performance positraction for Ford 8.8" with 28 spline axles
Auburn gear High Performance posi for Ford 8.8" with 28 spline axles. The Auburn gear limited slip uses a long-proven cone design to provide traction for performance and off-road applications. Auburn warranties their units for one year against manufacturing defects. These units are non-rebuildable.
Relevant Tags: POSITRACTION, POSI, LIMITED SLIP, DIFFERENTIAL, AUBURN GEAR, AUBURN
Manufacturer Part #: 542079
Ford 8.8 - 28 Spline Differential Posi / Positractions AG 542079-HP - Auburn Gear High Performance positraction for Ford 8.8 with 28 spline axles  View More Details
This is how i do it. You can UP date to CONE unit for much better performance. Replacing the entire unit is the way to go if you have the CASH. They also come in 31 Spline
I have a rebuilt trac loc with 1,000 miles on it, i'll sell it to you if you want.... when I bought mine it was the ford racing one and I got it new for $45. shipped lucky deal
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Gumby,
Thanks for that link!  Good grief that is a much better price.
Darren
