Topic: SN95 swap (Read 1459 times) previous topic - next topic
SN95 swap
ok so my friend just called and wants me to put a 4.6 in her boyfriends v6 94/95 mustang... they have the engine, trans, wiring harness, computer, and all accessories out of a mid 90's crown vic...
will they need a 4.6 k-member or is it the same in the SN95's between v6 and v8?
i'm just worried about the k-member and wiring/computer... i know i can make it RUN with the crown vic harness and computer, but whether i can make it work with the rest of the car, idk...
86 Mustang GT
SN95 swap
You will need the 4.6 K-member.
SN95 swap
thanks Chuck.
i think they are biting off more than they can chew (errr... afford)
they are thinking it's going to be a straight drop in plug in deal...
86 Mustang GT
SN95 swap
I think you'll need fuel lines as well. Good luck. It's never as easy as it looks. I hope you're getting compensated well.
SN95 swap
94-95 K-members are the same, 96-04 K-members are the same.  The 4.6 is much deeper than the 5.0.
V6 to V8 doesn't matter, it's what the V8 option was for the car that's important.  If the car really is a 94-95, a K-member will be needed from a 96-04 car, as well as 96+ spindles.
