Topic: Problem.. (Read 2709 times) previous topic - next topic
Problem..
Having a problem with the cougar, has a nasty hesitation. On a normal car you push the gas instantly the engine revs. The problem I'm having is you push the gas and it bogs down almost to the stalling point but than revs up. Once your moving it has no problem you hit it and it kicks right in with no hesitation. Not sure what it is??? Also don't know if it's related but my gas mileage has gone down as well???? kinda sucks when you try and take off from a parking lot and it has that hesitation.
:ford::oldcougar::mercury:
Problem..
I'm thinking TPS?
Problem..
That was KOEO incase you couldn't tell. Ran outta light was gonna get one with it running.
Problem..
that shows up as 11 11. System pass.
Problem..
EGR valve.
Problem..
...or maybe I can't read it either:dunno:
Problem..
Got me... I know it's annoying though. I need a nice day off to look into it.
Problem..
Just thought of another thing.. Don't know if it has anything to do with the problem but I had someone tell me it smells like the car is running real rich....
Problem..
Actually I tend to believe that's pretty normal for 3.8s
Problem..
Fuel pressure regulator? If you need one, i have a nice chrome stocker in excellent shape you can have............if a 5.0 FPR is the same. I have no idea.  It's just taking up space in the rolling tool box.
Problem..
Quote from: vinnietbird;362835
If he doesn't want it , I do ;)
Problem..
According to rock auto they are the same. I think I'll take you up on that offer.... Let me know what I owe ya.
Problem..
Gonna try and tackle this real soon... Anyway to test the TPS?
Problem..
The proper way to test a TPS is with a SCOPE. But lacking one you can use a Digital volt meter. Back probe sig-ret (blk-wht) and (dark grn-lt grn) and do a sweep of the voltage. It should sweep with no glitches or drop outs. Normally voltage runs .9-4.8V Closed to WOT.
