Topic: TC door panels on a Sport door (Read 1369 times) previous topic - next topic
So I am playing with the TC door panels and putting them into my sport. There are a couple problems with that. I noticed that the 2 bolt holes below the ramrest pad that hold the plastic too the door, the rear one bolts to nothing. The other thing I noticed is that the plastic part by the top of the arm rest (by the top where the door lock pad is), the tab is allways broken off. I know it hides behind the speaker cover. Is ther a repair or fix to that?
Thanks
:burnout:
There's little screwclips that you need from the TC doors to thread those screws into. As for the tab being broken, if you have the busted piece, you could superglue it.
I can't stand the TC door panels...I'm going to use the base panels, if I can ever find a decent set in gray.
I figured someone would have fixed this or modified it to work somehow.
:burnout:
You might check what I did with my panels.  FYI it's a PITA to do but it makes working in the doors easier.
__________________
Twin '85 TCs
White/ Grey 2-tone
