Topic: 87 3.8 fuel injectors don't work (Read 2950 times) previous topic - next topic
Ok, I will try to explain this my best .
 I got this car for my nephew via trade for his blown up neon.  when the guy brought this car over on a trailor it would only run at idle. If you tried to give it gas it would die. I poked around under the hood checking for vacuum leaks and anything else that looked out of place. I had him start the car up and  let it run for a bit then it just stopped running and no fuel is coming out of the injectors. You can't hear them ticking or anything. I have checked everything in the trunk and the fuel pump works fine and the filter still has good flow. I checked the pressure and it is good also . I can spray starter fluid in the tb and it will fire right up . All wires to the injectors are getting a 12v signal. Before I go buying a bunch of parts I figured there would be plenty of you fine gentlemen that could give me your input. Thanks alot for reading and helping out.
Just to make sure the ECU is firing the injector I would see about using a Noid Light. That is a little light type thing you hook up to the injector Harness to make sure it really is sending the signal to fire like it should be. That should help you sort out if it is the injectors or the signal to them.  I know some parts stores rent/loan the noid lights.
Hope this helps
Stuckman
I forgot to add that I did use a noid light . There is no signal change to the injectors.
If it has a TPS voltage problem(too high), the computer will go to de-choke mode and not fire the injectors...
Has it been checked for fault codes???
Don't have a code scanner here. And it doesn't run to go get it checked. So you think it may be the throttle position sensor? Would that throw a code
Shouldn't need a code scanner just a paper clip or a jumper wire. Can't think if witch pin on the big plug but jumper the single wire plug to the right spot on the big plug and it will flash the C.E. light and feed you the codes. I'm sure someone has the right pin and what code means what posted, do a quick search.
Stuckman
I did a search and tried it and it wouldn't work for me? On another note. I pulled the tps off and did a test with an ohm meter and it would stay zero most of the time and other times it would jump between 3-16 or 17 . So my guess is that it is no good. So if it is bad then is that what sends the signal to the ecu to make the injectors operate properly? Thanks
You need to test the Voltage from the TPS while it is hooked up to the car and on the throttle body. You should see almost 1volt but not 1volt or over while not on the throttle. Then you should slowly move the throttle open all the way looking for a drop out of the voltage. At full open throttle you should see almost 5volts. Sounds to me like you did a resistance test on your TPS.
Hope this helps
Stuckman
yes i did a resistance test. i'll give the other way a try
are the cats original on it.... my car did that years ago would idle fine, but would also die when you try to drive it.. clogged cats were the problem....
I tried a voltage test. I got a 5v input from the ecu (power side) and the output voltage was 0.14 volts ...lol . So I guess that tps is junk.
If you had it off and the screw holes are slotted type you would have to set it by sliding it into position. With the volt meter hooked up adjust the TPS so at idle you have a reading of .94-.98volts. Then once you are there Bolt it down tight. Then you need to work the TPS through the whole cycle testing for voltage dropouts while slowly working it to full open throttle. Why throw money at it if that is not the problem. Test it this way and make sure it is set up and works properly or not before you buy a new one.
Hopes this helps
Stuckman
I hear you on the buying unneeded parts. I did get the new tps and the car fired right up. But now it will run fine when its cold and then cut out and not run very good at all after it warms up ? I'm thinking it could be the plug wires.  This car didn't run when we got it. it only has 78k original miles and is in great condition for its age. Just really wanting to get this running for my teenage nephew. Thanks for the help
Well I checked the fp againd and it was only reading 20psi. I went ahead and picked up a new fuel pump assembly . The car runs great now. Thanks for all of your guys help on trying to get this car running.
