Topic: 1988 Mercury Cougar- Lowering spring- Help? (Read 1112 times) previous topic - next topic
I need help?? do you think a 1988 mustang lowering spring will work on a 88 cougar?
Why did you start another thread? You could have asked this in the other thread. A 5.8 is not much heavyer than a 5.0. The srings in a 83 and 88 should be the same.
I used mach springs all the way around and it lowered the car a lot I think that if I would have not went with the lower adjustable ride height arms in the rear I would be rubbing all the time now the only time I hear it rub is going threw a sever dip at high speed
87 TC
