Topic: manual vs auto in my cougar (Read 1994 times) previous topic - next topic
in my 83 i have the dash all ripped apart putting in after market gauges in where the old gauges were. while having the whole thing ripped apart i was thinking how easy it would be to put in a standard now, so what i want to know is what should i do?
built up a C4?
or throw in a standard?
my motors power is roughly 400hp 450 ftlb out of a 351w i'm currently putting in
i know a stock c4 or t5 won't hold up to it
is there another standard that will hold up that kind of power?
basically i'm looking for the cheapest route around all this, i know i can build up a t5, or a c4, but if there's something that's gonna be cheaper i would like to go that route
Life's Short, Go Fast
I'm in a similar HP range and I started with a four banger T5 and pretty much wasted that.A World class T5 can handle 330 ft lbs. I got my taxes back and went with a Tremec TKO 600 Rated to 600 ft-lbs. With a Quick time Blow shield. Now I can try and break that
    :burnout:
Look on the Mustang forums (Corral, Stangnet, etc) and look in the classifieds.  People are hurting for $$$ right now so if you have cash you can pick up some pretty good deals.  Building a T-5 to handle a lot of hp is like pouring good money down the drain as far as I am concerned.  From what I have seen over the years the WC units will hold together with 400 ft-lbs of torque as long as the rear tires never quite hook up.
Darren
You're going to have to pay for a decent trans. Stock units won't hold up to that kind of power for long....
Stick with the automatic. Especially if you want to drive around town often.
well guys, i know a lot of you guys may not agree with me, but what i just got today was a t5 world class tranny with a removable bell housing.
now what i need to know is what i gotta do to withstand we'll say 500 ft lb
any ideas?
i see there is a lot of stuff for these transmissions including straight cut gears, a lot more solid stuff, looks like there is a big market for these trannys.
any ideas would be much appreciated
i realise this might cost me a bit of money but since i got this tranny for free i'm willing to spend a couple bucks on it
also any tips for swapping this from an auto in my cougar would be appreciated, but i see there is alot of posts on this forum going from auto to stick in these cars.
but every bit of information helps.
i already got most of the dash ripped apart because i am putting in aftermarket all mechanical gauges in this car because the digital gauses gave me eff all for readings. had fuel, speedo, and odomotor, the rest was all just dummy lights which with a new 351w i don't really wanna take any risks.
everything is appreciated guys!!!:burnout:
My advice would be to sell it and buy a something that is better and will not break later on down the road.  You can put all kinds of internals in a T-5 and they will be almost bullet proof (http://www.gforcetransmissions.com/tran_gt-5.asp) but the real problem is the case.  It flexes and when it does this the internal parts get out of alignment and then you are left with a pile of useless parts.  Its your choice and I understand the lure of the T-5 but it has its limits not matter how much $$$ you throw at it.
Darren
