Topic: dead pedal install (Read 1583 times) previous topic - next topic
dead pedal install
First off the search function either sucks or I cant use it correctly!
It seems where I want to bolt the dead pedal to the sheetmetal, there is the bracket for the push plug for the trim piece.  I cant seem to fit it closer to the firewall, there is not enough room for it.  What the hell have you guys done?  It just bolted right in on the Mustangs. :shakeass:
Mike
dead pedal install
I was hoping I had a pic w/o the panel in place, but no luck. You can see mine is below the push pin though
dead pedal install
I bolted mine right to the push pin bracket
dead pedal install
Mine is also a little under the push pin hole.
