Topic: Help!!!! (Read 1213 times) previous topic - next topic
Help!!!!
The stock cam pulley bolt isnt going into my boport 2.5 cam. It goes into the A237 easily. I not sure if i should just try and punch the stock one through or what. Ive been to ace hardware a few times getting bolts and none of them worked. Any ideas?!?!
Help!!!!
Well, have you actually tried contacting Bo?  That would be the first place I'd start.
Help!!!!
yep ive called him a few times in the last hour and nothing and i wrote him an awhile ago and nothing
Help!!!!
Well, I suggest you keep trying.  He's going to be the one to answer that question for you.  He's probably busy in the shop.
Help!!!!
Tapped it out and it works great. I got ALOT of material out!
