Topic: RHD 83 Heritage (Read 32456 times) previous topic - next topic
RHD 83 Heritage
Reply #90
Love it !!!!!!!!!
RHD 83 Heritage
Reply #91
Changing the trim to black makes it a lot better.  For the bags did you use OEM bags from lincoln mark Vii or aftermarket stuff?
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
RHD 83 Heritage
Reply #92
Aftermarket stuff.
There are no Lincoln's over here, so it would have been difficult to source parts.
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
RHD 83 Heritage
Reply #93
aired out
95 Falcon GLi
RHD 83 Heritage
Reply #94
I love it !!!!
Get the front down a bit and perfect !!!
RHD 83 Heritage
Reply #95
Yeah i've ordered some MM Camber plates, when i install those i'll see if i can get the front lower.
As above is bottoming out the shocks.
if that doesn't work, i'll see if i can find some fox mustang struts.
95 Falcon GLi
RHD 83 Heritage
Reply #96
Forgot to update
Installed the MM Camber plates, which helped bring the front down.
Unfortunately overestimated hood clearance, so have a bit of a dint in it from the strut :/
excuse to get a cowl done.
95 Falcon GLi
RHD 83 Heritage
Reply #97
It's obviously not the same car, but your before pictures looks very much like my first 'bird.  It was a 1984, painted the same way (white-out-everything).
The memories..
T-Birds can't fly.  Ask how I know...
RHD 83 Heritage
Reply #98
95 Falcon GLi
RHD 83 Heritage
Reply #99
Someone stole yer engine!!!!!
Seriously, it's not fair to tease like that without at least a LITTLE details as to what's coming.
RHD 83 Heritage
Reply #100
In Aus, our ~1998/1999 Ford Falcon's had a Explorer Spec 5.0 available.
so Roller Block
GT40P's
Cranecam 444225
crane roller rockers
crow valve springs
I've got a Powerdyne Supercharger to suit the engine itself, but i think the Bracket setup will have it sitting too wide, so it may or may not be used.
either way, should pretty much double the power it had with the original motor :)
95 Falcon GLi
RHD 83 Heritage
Reply #101
wow so weird seeing the firewall all backwards like that. :P  I'm being serious!  Also ya gotta keep the stock hood look.  Any chance to get a turbo coupe hood for cheap where you're at?
RHD 83 Heritage
Reply #102
Nah not a chance.
I'd be surprised if there was even a Turbo Coupe in Australia.
95 Falcon GLi
RHD 83 Heritage
Reply #103
slowly but surely.
Still need to work out the headers on the Drivers side.
as expected, the shorties interfere with the steering shaft.
Started cutting up some other headers i had laying around, but i need to get a new starter to check clearance.
95 Falcon GLi
RHD 83 Heritage
Reply #104
Not much more to show yet.
Although its now running after finding 2 dud injectors.
engine bay is more Aussie Falcon then thunderbird now, which should make life easier for replacement parts.
Needs tidyup and to install the TV Cable before its drivable.
95 Falcon GLi
