Topic: AOD transmission (Read 1702 times) previous topic - next topic
AOD transmission
Is the AOD transmission in my 87 5.0 the same as one out of a 91 SuperCoupe with a AOD. Will it bolt up? What all will I need to change to get it to work. Will I still use the same driveshart?
AOD transmission
It'll bolt up.  The SC trans is actually a bit of an upgrade as far as durability is concerned....
It's the same length so you'll have no issues with the driveshaft.  The drive gear in the tailshaft may have a different number of teeth so you may need a new speedo gear.  The SC should have an 8 tooth gear and the '87 should have a 7 tooth gear provided they have the original tailshafts.  The tailshafts ARE interchangeable....  The later style is said to have fixed a lubrication issue.
FWIW -- when I bought my car in '98 it had a brand new AOD in it with less than 100 miles.  Had a case with an '89 part # and the later style tailshaft with the 8 tooth gear.
AOD transmission
i should have done that instead of buying a dam jasper tranny.  aboslutly the WORST decision i ever made.  should have just put a new front seal in my old one.
AOD transmission
Thanks for the info that helped a ton. A buddy of mine as an extra SC transmission laying around that he said I could have.
AOD transmission
O what would it take to make it work. Just switch over the linkage stuff?
AOD transmission
if you have a floor shifter, your all set to just swap it and change the speedo gear. If you have a column shifter, you have to flip the linkage lever over to make it connect up
AOD transmission
Thanks I have the column shift and I hate it.
