Topic: Need Two Pieces for my Floor Shift Conversion (Read 726 times) previous topic - next topic
I have almost everything to convert my aod to floor shift.  I still need the bracket that bolts to the transmission to hold the cable away from the tranny.  I've heard that this bracket is different for the four eyed cars, but I don't know for sure.  I also need the shifter arm that goes on the end of the shifter lever coming out of the case (it's different than a column shifter arm).  Anybody out there have these parts?  Anybody know if the bracket is indeed different?
I've turned the lever on the trans around before, from pointing up to pointing down. It was on an '87 aod though.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Right. I know I flip the lever over, but Eric's site says that I also need a different arm for the end of the lever.
I found this adjustable lever from Lokar.  I think this solves one of my issues, but it comes in two sizes, 1/4 and 5/16.  Anybody know which one is used in the T Bird AOD?
I would still like to have the factory pieces if anybody has them...and I still need the bracket that holds the cable off the transmission.  Anybody?
