Topic: Biggest 15" tire on a TC (Read 2714 times) previous topic - next topic
I want to possibly stay with my ten holes, but a want to put some thick old school raised letter white tires in it.Like that Starsky and Hutch type look. Whats the biggest meatiest tire I can run in the back and also what should I run in the front. I want that old school street strip look. I want a tire that will safely fill the wheel well with a car that is not dropped or lowered at all.
you mean something like this?
Quote from: daminc;357989
Yes! What size did you go with?
That size right there, lol.
shiznitfire, I love the look of turbines on a fox with raised white letter tires...
I have 255s on the back, and pretty sure I put 225s on the front...
Quote from: daminc;358004
are they 60's, 70's? In other words 225/60/15 or 225/70/15? Can you be more specific please. Thanks
Quote from: ThunderbirdSport302;357999
You and me too, brother.
Mike
Have you tried http://www.tirerack.com and looked up different tires?  They typically specify the width of rim for the tire that will get you the largest contact patch.  Too narrow of a tire will cause the outer edges to wear prematurely and too wide of a tire will cause the center of the tire to wear prematurely.
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=Radial+T%2FA&partnum=56SR5RADTARWL2&vehicleSearch=false&fromCompare1=yes  Click on the tap that says "Specs"
The Mustang guys will run up to a 275/50/15 on the 15 X 7 ten holes but they wear badly.  A 255/60/15 is just about perfect as you can see from the pictures above.
Darren
Quote from: RDOG;358017
Sorry, turbines are 60s
I run 255/60-15's on my rear 10 holes.  It's a 27" tall tire.  I really wouldn't go any wider on a 10 hole -- unless you widen the rim itself.....
I have 235s all around. No rubbing.
I have 235/60s on 10 holes, all around and no issues, either (other than noticed a bit of power loss due to the slightly taller gear I created going from a 225).
Don't laugh...with a bone stock V6, I need all the help I can get!
'87 Cougar LS V6 (stock) Daily Driver
'06 Lincoln LS V8
'12 F-150 SCrew FX4 5.0L
'80 Thunderbird V8 (mild 304) [sold to friend]
