Topic: turbo boost (Read 1401 times) previous topic - next topic
turbo boost
on my 86 2.3 turbo cougar xr7.HELP  car runs great,idle ,tuned,smooth only one boost issue.Car seems to red line more often than before.sometimes at 18-24 psi boost it bucks,lags and backfire.{only at max boost. any info,help ?orig turbo,owner,90.000 miles
turbo boost
If your car is stock or near stock it has no business at 18-24 psi.  An 86 XR7 should only be making about 10 psi.  I would inspect your vacuum line to the wastegate and make sure your wastegate isn't sticking shut.  I would check this out immediately as the engine won't live long without an intercooler and with a stock fuel pump making that kind of boost.  If you have to drive it, stay out of the boost.
turbo boost
With that much boost your injectors and fuel pump can not keep up. Going lean like that can cost you a head gasket real fast. Check the hoses as recommended and also the stock boost control solenoid, not sure what type you have but the round black plastic ones are famous for falling apart.
turbo boost
First off, a list of modifications (if any), are going to be of great assistance.
turbo boost
no mods all stock and original
turbo boost
WAAAAAAYYYY too much boost for that stock fuel system.
Turn it back down to a reasonable level (13-15psi max).
By "redlines", do you mean it boosts out of control?  If so, you have a wastegate, or WG actuator, issue.
turbo boost
You better check the Vac line going to the wastegate actuator.  You are really trying to destroy that engine by doing those boost levels.
Mike
turbo boost
I must say something is wrong, The redline part really confuses me. All I can think of is that your telling us that Little Buzzer telling Overboost is sounding? Red Light comes on, sounds the end of the world at those pressures? Or are you saying the motor hits redline faster than before as in RPM's? Well your saying its all stock if so something is affecting the boost level, check that vac line to the waste gate actuator, Check the actuator and the waste gate flapper operation, also check the vac lines and BCS if your car has one. With it being stock and running that kinda of Boost as long as the Knock sensor is hooked up it would be retarding the timing if is senses knock. With 18-24psi I would think there would be some knock going on.
Stuckman
