Topic: summer oil in a 5.0 (Read 1298 times) previous topic - next topic
summer oil in a 5.0
What oil should I run in my bird I threw in this motor to be able to drive the car while I am building a new 331 the current motor has about 120000 on it. It doesn't burn oil or leak but I have noticed that since its getting warmer out my oil pressure is dipping down a little bit. when its cold it runs around o on the normal and when its a little warmer out it runs between the o and r and sitting at an idle warmed up on a warm day it will drop down to the m I was just wandering if I should go with a little thicker oil for summer I am running 10w30 currently
87 TC
summer oil in a 5.0
I run Valvoline 20w50...
summer oil in a 5.0
I really dont drive my car much in extreme cold, but in the fall I run 10W30.  In summer I run 10W40.
Mike
summer oil in a 5.0
Get a pressure gauge on it so we know what kind of psig pressure it is running versus letters on the factory "gauge".  I have seen way too much variance on the factory "gauges".  I bought a mechanical one from AutoZone for about $15 a few years ago and it has fired off several new motors and I have used it to trouble shoot other issues.  I typically run 20W50 here in Texas year around on the Coupe but our weather is a bit different than up north.
Darren
summer oil in a 5.0
15w-40 shell rotella t is what i use to run in mine in the summer.  i run 10w-30 shell synthetic blend now and it runs great on it plus my motor has 224xxx on it
summer oil in a 5.0
Best stuff on the market for a car that needs zinc IMHO
It's expensive, but you can go quite a long time between changes and the zinc content is higher than rotella.  It's a full synthetic as well.
