Topic: Gauge cluster, Mech or Elec? (Read 982 times) previous topic - next topic
I am redoing the gauge cluster on my 88TC and cant decide exactly how to do it.  I am getting all Phantom gauges, and I am tryin to keep it as cheap as possible.  I am going to use the original cluster but redo the face.  I am going to overlay it with plastic and drill holes for the turn signals and high beam. Then I will re-cut the holes for the gauges with the oil/temp and amp/fuel gauges at a diagonal(2 1/16" gauges). I will be using a 3 3/8" tach/speedo.  The easiest thing for the oil and temp should be electrical and hook to the existing sending units correct?  While the amp connects to the alternator?  I am unsure of how the fuel level needs to connect though. Which ohms do I need?  Now the tach...which one is best/easiest to hook up, mech or elec?  And the speedo...can I get a mustang cable and run it to the TC 5-speed?  Either way I want to keep the pigtail so the dummy lites and other stuff works.
yeesh, nevermind.  Over $500 bucks in gauges.  I ordered white faceplates instead AND they have replacement LED bulbs for the cluster. I ordered blue.
