Topic: TC electric fans on a 3.8 V6? (Read 1522 times) previous topic - next topic
Hey guys,
I've read countless threads about the TC electric fans not being compatible with a 5.0, but I haven't found one yet about the fans working with a 3.8.  Does anybody know if there is pulley clearance on the 3.8 for the electric fans?  Thanks for the replies.
Fordman3
Re: TC electric fans on a 3.8 V6?
Because the 3.8 is so much shorter, I'm betting there's more room... enough room though?  WHo knows.
Ifixyawata,
Thanks for the reply.  What is the critical dimension I would need to know?  From what point to what point?  I'm assuming I would remove my mechanical clutch fan and shroud and the whole TC electric fan assembly would go in their place?  What does it mount to or from?  Aside from a little unnecessary draw from the battery/alternator, and because I don't feel competent enough to wire the elec. fan up the right way (primary fan on/off from thermostat reading, secondary fan on/off with AC on/off, etc.), what would be the harm in running both fans constant with an ignition-on power source?  I'm primarily looking for a mpg-gainer by freeing up some load on the motor.  Sorry for all the question marks in a row, but I appreciate anybody's thoughts.  Thanks.
Fordman3
If you don't feel competent enough to wire up a set of TC fans, I would probably pick up an aftermarket electric fan.  Unless you've got the TC's sitting around I wouldn't bother trying to install them.  Hayden and Imperial (same company, different name) make pretty good fans for pusher or puller setup.  They also have very clear instructions and wiring kits.  I couldn't be happier with mine.  The only thing I would do is maybe get the 16" instead of the 14".  I've had no problems, but cooler is always better.  Here's the thread with pictures:
http://www.foxtbirdcougarforums.com/showthread.php?t=1803
1987 Thunderbird 3.8. Sold :(
youll need the TC upper radiator brackets, and i dont know how the bottom mounts up,  probably the same way as the normal shroud does
wiring is simple, if you pick up the proper relays
