Topic: Replacing batt cables (Read 1236 times) previous topic - next topic
Ok, I have become dis-intrested in my cougar so am going to start driving my 83 Bird again but have a question. I am going to change the battery cables as these original ones are very brittle. The neg cable has a small bracket that mounts it to the fender apr0n and then it continues down to the block.  Does that bracket also work as a ground? Everything at the parts store is w/o the bracket so should I replace it and forget the bracket or use 2 cables, 1 from block to apr0n and 1 from apr0n to batt?
You may find this helpful....... or as I did educational since this was my ride.:punchballs:
http://sbftech.com/index.php/topic,29696.msg315271.html#msg315271
