Topic: 65mm TB (Read 1332 times) previous topic - next topic
65mm TB
What year mustang has the Throttle body style i need to put onto my intake? I used to know but i forgot....
65mm TB
Don't waste your time with a Mustang unit. The throttle body from an 89-95 Thunderbird Supercoupe is the one you want. Even has the correct ball stud for the throttle cable.
65mm TB
Is it a 65MM?
65mm TB
An Explorer or '93 Cobra throttle body will be 65mm (Cobras cost a lot more). The Explorer t-bodies can be found cheap, and only take a few minutes to convert over to Fox use. I have an Explorer t-body on my car...65mm. I polished the inside after I removed any molding lines, and sharpened the blade (doubt tit made a difference, but I figured while I was in there....), I also rolled the edges (where the air enters) don like a trumpet. No air obstructions. I've seen them cost anywhere from $20 to $40.00. Not bad at all. Cheaper than aftermarket, and readily available.
65mm TB
First off, the Supercoupe unit is 60mm, and would flow enough air for about 400-425 horse. For a street/daily driven TC, there's simply no need for anyting larger. Plus, as already mentioned, it has the correct ball stud for the throttle cable, which the mustang/explorer unit will not have. All thats needed when running the SC unit is an offset bracket to move the throttle cable connection further back on the upper intake.
65mm TB
I have a 65mm Explorer throttle body I'm planning to sell . Converting it is easy.  You can find the instructions on the net.  Shoot me a pm if you're interested.
65mm TB
Oh wow looks like i'll be getting a Supercoupe TB! thank you Very much for your help!
