Topic: Bullseye mounting (Read 2639 times) previous topic - next topic
Bullseye mounting
So when i picked the car up originally, it had the bulls eye still with it, but the mounting spring and hardware was long gone. Also the little loop at the bottom is broken, may be the reason its not on the car anymore.
I just wanted to know if you guys had had any luck re-mounting these, as well as if there are any popular fixes for them. I know that if I need the hardware I can make a quick trip down to the yard, and s one out of another vehicle.
Here's a pic of the piece:
Bullseye mounting
JB Weld :hick:
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Bullseye mounting
Yeah i had some of that stuff on there, but with the cold temperatures up here, and the fact that i can see it getting bumped or smacked all the time, it didnt work too well.
Bullseye mounting
Just hit the yard and/or Ebay and grab another one.
Bullseye mounting
When I worked for MB we used to get aftermarket hood stars that you could pull out of the base and remove to avoid it ending up on some misfits necklace, I think I might still have one so let me check and if I do I can send you some pics to show you how it mounted. Once its on the car you can't tell as it looks original
Bullseye mounting
Quote from: vinnietbird;357390
Easier said than done.
Bullseye mounting
You can always go NOS...
http://cgi.ebay.com/ebaymotors/FORD-HOOD-QUARTER-ORNAMENTS-MERCURY-COUGAR-1986-81-NOS-_W0QQcmdZViewItemQQhashZitem4151fb4239QQitemZ280548295225QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1961wt_941
LOLz!
Seriously...sometimes they pop up on eBay for waaaaayyyyy less than that.
Bullseye? Hrmmm...
Bullseye mounting
I would myself see if I could find some very small metal tubing Stainless if possible. I can find it at lowes and home depot sometimes the KS metal rack or even online or a Model/RC type hobby store. I would see if I could find some where I could drill and maybe get a press fit or silver solder it in there. Then you would have the hoop part back. I haven't done this but that is what popped in my head for a fix from that pic you posted.
Stuckman
Bullseye mounting
when the one got pulled from my 79 I took the spring and wire from another and beat the broken loop closed around the wire and its held ever since. and those was 9 years ago..
Bullseye mounting
eric, there are 2 different sizes of these, the 77-79 use one that is about 3" diameter and the 80-84? use one that is about 2"X
