Topic: Brake Bleeding (Read 2019 times) previous topic - next topic
Brake Bleeding
I am in the process of rebuilding an 1988 Cougar LS, 5 liter, V8. I am having trouble bleeding the brake system, I have replaced the brake lines from the master cylinder too the drums and disks. The rear brake line will not bleed out, could this be the cylinders are shot or am I missing something with the bleeding process.
Thanks
Andrew
Re: Brake Bleeding
Maybe the rear rubber hose has colapsed or the cyclinders are froze. or the line is pluged. Also have you trie a mty vac? a vac pump to suck the fuild through you can get one for $40 at the parts store called a MITGHY VAC by name and brand
