Topic: You need subframe connectors (Read 17664 times) previous topic - next topic
I just got subframe connectors welded into the T-bird. If you don't have any on your car you really need to get some. The car rides smoother since the floor pan isn't flexing and it corners flatter. Overall it's one of the best mods I've done.
I agree it really helps.  Do you have any pictures?  Did you make your own or buy them made up?
I purchased mine from someone on eBay but they were so simple that the next time I would just make my own.  Just some channel and flat steel.
TED
I bought them from V8Demon. They were made by Stinger, who no longer makes them. They could easily be made though but I got a deal on them. Plus I didn't want to have to find someone to make them for me.
I'll try to take some pictures in a day or two. I just have to go out to the garage and jack up the car.
I would love some that don't go through the floor. I wonder who could fab a set and send them to me.................
All you need is some channel and flat steel.  The channel needs to be as wide as you subframe and about 1 inch high.  Clean the subframe, lay the channel flat and tack on, lay flat steel to the side and weld solid.  The one they made for me is a bit narrow and it made welding a bit harder but it worked.  This may reduce you ground clearence slightly but it never been a problem for me, my exhaust is still a bit lower.
I'm sure that thunderjet302 will post pictures that will put mine to shame.  But this sure did make things a lot stronger and everything better, even shutting the door is solid.
As a side note I had a 1988 Mustang on the hoist this week-end and I cannot believe how light duty they are compared to the T-bird (at least my 87 Turbo Coupe).  I don't know what keep a Mustang from folding in two.
TED
I have a set that has been propped in the corner of my garage for 4 years.  I need to get those welded in sometime...
I think that may go on the list over the next few months. I have a good friend who can have them welded for me.
They make a big difference. When I welded my KB ones on I could tell the difference even just driving around in the yard...
They're on my list of stuff to do as soon as I get mine in a mobile state.
Holy  Ted! Where have you been hiding!
P.S. I know I need subframe connectors, but not yet! She corners pretty good as-is.
Here are the pretty pictures;).
Thanks for the pictures.  Maybe you don't need the flat plate on the side but I think it makes it a bit stronger.
TED
are the sub frame connectors t-bird specific? will a set of maximum motorsport xl full length for mustang fit?
That looks easier than I thought. I was looking at a through the floor set up I might go that route. Anyone have pics of through the floor subframes?
Quote from: BlackBird88;357182
10 feet of 1x2 steel stock is all you need , 5 feet per side
