Topic: SN95 brake swap(ball joints) (Read 2195 times) previous topic - next topic
I need clarification on some issues with swapping over to SN95 brakes. I've read up on the swap through CoolCats and will be sourcing all my parts from a 95GT to install on a 88 Sport. First question concerning balljoints - do the SN95 ball joints press into the stock control arm or do i swap out entire lower control arm? Second question - how do i go about replacing the inner tie rod ends if necessary? And last - I know I've read somewhere about changing out master cylinder and prop. valve, but what is the recommended bore size to run disk rear? Thanks guys...im just starting my mods so any help is greatly appreciated.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Re: SN95 brake swap(ball joints)
Quote from: slicksport88
You can press in SN95 balljoints, stack hardened washers to a height of .330", or swap in an entire SN95 control arm.  Personally, I'd buy the 2003-2004 Cobra arms from Maximum Motorsports. They'll replace your worn out bushings with ones of higher durameter (stiffness), new balljoints, and a stamping that has increased clearance for deceased turning radius with big wheels
Second question - how do i go about replacing the inner tie rod ends if necessary? .
jcassity has a tie rod replacement write-up here somewhere. PM me if you need more detailed information/pictures.
Hmm, your setup is somewhat ized.  The SN95  disc/caliper has a diameter of 10.8"/66mm.  Given some assumptions such as pad placement- for a given pedal pressure, the SN95 setup will apply 30% more torque to the wheel than the Fox setup. You'll definitely need a new prop. valve to keep the rears from being (more) useless.
From the look of your questions, you haven't taken enough visits to Eric's site. Here's the url... http://www.coolcats.net/
Matt90GT's website has a plethora of SN95 brake swap info, here.
Thanks for the info...one thing I didn't mention which probably had you asking " why is he doing that? is that I am using spindles and axles off the 95, however installing cobra brakes front and rear. Matt's site was a big help..had all the info I was looking for.
