Topic: A/C Compressor to valve cover?-fixed, delete thread (Read 979 times) previous topic - next topic
Mine hits the cover and wont let me bolt in the compressor. Im using Mustang covers. Id hate to try to grind on one or the other and ruin something. I cant grind on the bracket, or Ill throw off the belt alignment.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
We need a pic. Even with aftermarket covers, my compressor doesn't touch the valve cover. Plenty of room.
It just took a BFH, and screwdriver to bend the brackets into place. carry on.
87 Thunderbird LX
I had the same issue with with the Ford Motorsport covers. IF you intend to keep the A/C like I did, you can lightly grind the comp and a do a light grind on the VC followed with a good buffing.
Glad you got it fixed. We've all been through it.
