Topic: Rear window question... (Read 1128 times) previous topic - next topic
When you remove the rear window on an '88 Sport, is the trim glued to the glass?
Do you just cut it out, like when you do a windshield? Thanks.:bowdown::D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Herb , is it the one piece gasket style trim  ? If so it it comes out before the glass, it has a lip that clips into a channel, you have to get something underneath it and pry it up.... once you get it started it comes right out .
I used a popsicle stick .
Wow, who would have thought it would be that easy!!! :hick:  Yes it is the one piece one, thanks for the advice, I used a small screwdriver and it popped right off.  :D
