Topic: Billet grills I cant believe it!!!!! (Read 5084 times) previous topic - next topic
Quote from: RareBreed 5.0;360005
I like it, but i think it would look even better if you painted the color of your car to give it that "Factory" look.
then it would look loke this lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
think i prefer the stock grill
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
After market leave it all Bling!
I think it looks great! It sucks you had to put so much work into it just to make it fit but at least the end result looks to be worth it. It was the same with my hood, it took a good bit of work to make it right but I love the end result.
I hear you on that, I bought the same hood, but now my hood fits better then the stock one did.lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I still have to use a hook to lift it enough to get my hand under it because of the lip it has but I'm willing to put up with it.
oh you are supposed to cut all that off. I have about 3/8"-1/2" of lip on the outside, and smooth under the cowl.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
We were afraid if we cut it down it would come apart since it's got the finished underside. Seeing your's now, the next time I get the car painted it'll be getting cut down. Have you had any cracking? Mine has a couple on the sides of the cowl. Nothing major but they're there. They'll be taken care of as well when I get it painted again.
yeah one on the corner where it was dropped and repaired before I bought it(that's why I got a $350 refund!!!!)I thought I had it fixed but the paint kept sucking in, and one little split on the very top of the cowl near the edge.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Yeh, I knew it wasnt a plug and play unit. I paid some guy to fab mine up before I had my first billet grille made (4 years ago before this grill even came into production). The manufacturer should put in a disclaimer that the grille surround needs to be professionally modified for the grille to mount.
this was a total pain in the butt, finally got it ready for paint, just waiting to paint my other parts
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
All done
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I think I need to clean myself up now. Looks sharp!
Very nice! It looks great, I can't wait to see it on the car.
