Topic: 88 tbird getting molested (Read 24973 times) previous topic - next topic
Reply #75
Holy snikeys!  That thing is going to make some power!!!!  I guess with the twin scroll it should spool up faster?  What is your hotside gonna look like?
Reply #76
Reply #77
Quote from: The Shredder;356589
It will when I eventually get a quick spool valve.  Hotside will just be 2.5" and turbo will be on driver side.  I'm not sure what I'm doing with the downpipe yet.
Reply #78
I made a little progress today.  Everything came in to build my hotside so I did a little work on that.  I was going to mount the turbo with the inlet facing forward but that really wasn't possible on the driver's side so I just turned it.  Excuse the py welds, I don't know how to weld and flux just makes it worse.
Reply #79
X
Reply #80
I was wondering what that hole in the fender wall was for.
Reply #81
That turbo is massive.  I still need to cut a little more out of the inner fender but it's close.  I have several more pics but I'm having trouble uploading them for some reason.  We welded up a pretty trick brace for the turbo today.  As soon as I drop the motor in I'll fab the hotside.
Reply #82
XX
Reply #83
XX
Reply #84
XX
Be nice on the welds lol.  I don't know what I'm doing and using flux isn't helping the situation.
Reply #85
Won't be hatin' on that! Looks good! I like the brace. Actually for flux welding it looks awfully good to me. Plenty strong enough. This is gonna be a cool build.
Are you making your own collector at the turbo or buying one? I assume you are running each bank into a separate side of the turbine? Looks like you'll be punching a hole through the frame for the oil drain.
Reply #86
Looks good to me,good penetration and with a flux and two different gauge steel it looks fine
Reply #87
Quote from: flylear45;357059
Yeah I'll be making my own merge.  I'll probably be starting on it this afternoon.  I'm actually not running the banks to separate sides of the turbine because eventually I'm going to be running a quick spool valve and that needs an open .  Yep, oil drain will go through the frame.
Quote from: thewestie;357066
Thanks guys, I'm taking my time with this and trying to do it right.
Reply #88
XXX
Decided to start on the merge.  I'm using 2.5" aluminized tubing and an extended T6  from Race Parts Solutions.  I took a lot of pictures as I was doing this.
Reply #89
XXX
