Topic: 88 thunderbird turbo coupe (Read 13048 times) previous topic - next topic
i am transplanting a 5.0 in what used to be a 2.3 turbo and just for everyones info you have to change the k member if you use the v8 t-bird stuff it sets motor uo to high
__________________
Twin '85 TCs
White/ Grey 2-tone
X 351 Windsor performer intake stock 87 turbo coupe K member and the hood closes no adjustment Why would you change the k member
Quote from: ronnieburd69;353759
Funny, there's a buncha guys with swapped in 5.0/5.8, 429/460 engines who will call bullshiznit on that.
The ke member are all the same, '86 through '88, regardless of engine, in Tbirds/Cougars. Anybody that told you different has an advanced case of rectal-cranio inversion.
The only gain you MAY get with swapping in a Stang K member is the availability of aftermarket mounts, but even that's pretty well wasted time since Chuck sells V8 conversion mounts for '86-'88 k-member cars.
I'm not exactly sure, but I seem to recall CWE mounts enabling the engine to be a tiny bit lower than the stock stuff. Might contact him for sure though.
Again, to reiterate: ALL '86-'88 2.3, 3.8, and 5.0 engine cars share one common k member.
Remember that also certain year k member swaps will also require different control arms to keep front end geometry intact...there's a detailed thread in the suspension subforum about that.
Now, what is the problem with the engine being too high? Carb motor, or fuel injection? If carb, what intake, carb, and what size air cleaner are you running?
There's a fella here with a 460 under a stock, uncut hood without clearance issues...as well as a guy with a Caddy 500" engine, but I can't recall if he modded his hood or not...
Search is a handy tool... good luck.
Thats funny I currently have a 5.0 in my bird stock K with stock V8 Bird Mounts. I did remove all of the air dam stuff underneath the hood. I think the air dam would hit the motor if not removed but not sure I removed all of that before I put the hood back on.
87 TC
AFAIK the only FOX K-member that has to be swapped for a 302 or 351W to fit is the I6 K-member. A 302 or 351W bolts right into and FOX that originally came with a 2.3, 3.8, or 302 with the correct mounts.
Y'all keep changing them motors in T/C's to 5.0 and there won't be many 2.3L Turbos left. Yes it will make my car more rare but I prefer to see them with the 4 cyl turbo as they were made. Oh well, to each his own. I know, put twin turbos on it and it still will be a turbo coupe!!!
88 Thunderbird Turbo Coupe- Gillis, 17 PSI, Tripminder
All stock, Showing and driving to peak interest in our cars.
Runnin' Strong & Flyin' Fast:birdsmily:
Well I for one will be putting serious thought into a v6 swap for my turbo coupe once ford decides to offer the ecoboost crate with a standalone
87 TC
Then you did it wrong.  Your 88TC K-member is the same one as used in the 88 5.0.  Actually the only part of the motor mounts that's even different are the pieces that bolt to the engine.  The isolator, and the lower U-bracket are the same across all engines.
Hum wonder why he hasn't replied to his thread yet
87 TC
I did the 5.8L swap in my Sport. Same K member as the TC. No issues here. I guess I should have wasted my time installing the Fox mustang K member in my Bird to do the engine swap.
:burnout:
Quote from: bigbada1;353842
I agree, I have an 87 T/C that I am waiting for the Ecoboost V6 out of a Truck. I want to transplant the entire drivetrain into it. I think it would make an economical and extremely quick and fast car!
I bet that ecoboost truck engine wont fit the engine bay of the Thunderbird. I replaced an ecoboost engine in a truck a few months ago. It is a very wide engine with the twin dryers on it. Plus it is a very tall engine too. It would need a lot of fab work from the exhaust to intake. Then trying to get the electronics to work with the engine and car. Nothing is simple with these engines.
:burnout:
Any newer Dual over head cam...is a packaging nightmare...the heads are so freakin big..
Travis
Quote from: turbotrav;414907
Travis
Agreed...
If I'd known more about the LS Chevy there'd probably be one under the hood of my TC now... About a year ago a friend sold a wrecked 6.0 van(even still sort of drivable but frame was bent) with less than 30K on it for $1000, oh well hind sight is 20-20...
Oh yeah to the OP, here's another TC that's had a 5.0 since '99 using the original K member(see link under pict)... All that's necessary is the 5.0 mounts for a '86-'88 Bird/Coug, no earlier or Stang mount is going to work...
