Topic: Pedal assembly (Read 1050 times) previous topic - next topic
Pedal assembly
Im going for a T5 swap on my 87 Thunderbird, and im looking for a pedal assembly in good shape....
Vegar - Norway
Pedal assembly
you need clutch cable too? I can get you a set of T5 pedals but they use the cable set up, not the hydralic clutch.
Pedal assembly
Hi Sarjxxx. Cable set up is fine.
Vegar
Pedal assembly
It would have to be a cable, as there were no Fox V8 cars with hydraulic from the factory. However, you can use the aftermarket stuff....err, now I can't find my bookmark.
Pedal assembly
Ok well if you're interested, I think I can get them to you for about $70-80 total. I know that sounds like a lot, but I have no idea what its going to cost me to ship them to Norway, and the junkyard isn't going to let the pedals go for cheap, but I'd say the total price including shipping should be no more than about $80 US. If I can get them to you for less I'll be sure to let you know before I have you pay me and all but if that sounds like an amount you'd be willing to pay, let me know. Also let me know if you need the clutch cable to go with them cause I can get it too if you need it.
Pedal assembly
Hi, might not be factory, but I put a t-5 in a 88 t-bird sport using the hydraulic set-up out of a turbo coupe. I had to make a mounting plate for the slave, which took about an hour, but then it went right in, with no more problems, and worked fine. I never was a big fan of cables.
Pedal assembly
Quote from: sarjxxx;353857
The price is fine with me, i cant find the pedals here in norway. there isn`t many fox bodys here. is the clutch cable on the t-bird different from a fox mustang? im looking at a complete pack with clutch quadrat and cable from summit racing. Thanks, Vegar
Pedal assembly
No, I don't think its any different. The pedals are the same so the cable shouldn't be any different. Sometime next week I should be able to get out there and pull those pedals out. I'd like to say Monday but I don't know for sure. I'll keep you posted.
Pedal assembly
Thanks. Im leaving for work on monday, so i will have a limited internett access. I will be away for 2 weeks. Just send me a PM and we will work out the details...
Vegar
Pedal assembly
K. I'll send PM when I get them pulled out.
Pedal assembly
If it fits a Fox stang, it fits a Fox Tbird or Cougar...speaking of the parts you're looking for, that is. If you can get an adjustable clutch cable, that's the best option. Some are a lot better than others though, I've heard some bad stuff about BBK cables...
Pedal assembly
Thanks for the info, ThunderbirdSport302
