Topic: bumpers and covers (Read 6508 times) previous topic - next topic
bumpers and covers
Will the 87/88 bumper fit under the 83-86 cover?
__________________
Twin '85 TCs
White/ Grey 2-tone
bumpers and covers
It's a totally differant shape? I wouldn't think so. Do you need an 83-86 bumper? I have several
John
bumpers and covers
Looking to trim some weight without impacting (nyuk nyuk) safety.  I blame fordguy545 and gumby for this thread.
After seeing fordguy545's trimmed bumper, it got me to thinking about using pre-preg CF *as a reinforcement.  Trim a factory metal (or fiberglass) bumper of as much material possible, lay the pre-preg, bag and cure it.
* http://tinyurl.com/46kcwht
__________________
Twin '85 TCs
White/ Grey 2-tone
bumpers and covers
If you are gonna be tpuppies it, and already planning to lay the pre-preg CF, I'm sure you could make the 87-88 bumper fit nicely inside the early cover. :evilgrin:
The 87-88 bumper would make a much lighter base to begin with, and likely a fairly easy substrate to bond the CF onto.
I already have a few guys who blame me for certain car hobby related choices they have made; get in line :nkhk:
Another thought:
I was considering a CF or fiberglass hood but don't see that as a viable choice now.
fordguy545 shed a few pounds by removing part of the underside support frame of the hood and trunk.  Would a sheet of pre-preg laid on the underside restore the some or all of the stiffness?  It would be easy to prep the surface then bag and cure it.
__________________
Twin '85 TCs
White/ Grey 2-tone
bumpers and covers
Workin from what I see on our racecars that have CF bodies, rather than adding thickness to the entire panel for rigidity there are patches added only to the specific areas that require it. I would assume the same would hold true on the underside of a sheet metal hood to some extent.
bumpers and covers
Bumper question - are the bumpers straight bolt-in swaps with regard to mounting (not counting bumper cover)?
Lid questions - I ASSume the loss of rigidity is torsional and not surface deflection?  If one were to chop the underside like 545 did, then lay a sheet of CF everywhere there wasn't the reinforcement, would that work like the mods on the race cars?  Or would a third layer of another material need to be added, eg foam core?
__________________
Twin '85 TCs
White/ Grey 2-tone
bumpers and covers
SWAG ahead:
I would say a web of CF strips bonded directly to the hood, and located where you remove the reinforcements, would make a significant decrease in flimsiness.
Additionally, If you cut some 1" foam in the same layout and bonded that to the hood like a hat channel(similar to uni-body channels), you would add a large amount of beam height which would add to torsional rigidity.
bumpers and covers
Gumby, not sure I know what you mean.  Are you suggesting cutting foam pieces to fit so that the CF has a relatively smooth flat shape?
__________________
Twin '85 TCs
White/ Grey 2-tone
bumpers and covers
Basically you would use the foam to replicate the layout of the braces that are cut out, then lay the CF sheets over that. x's are foam:
[PHP]
  ____
__|xx|__
[/PHP]
bumpers and covers
ah, got it, thx.
__________________
Twin '85 TCs
White/ Grey 2-tone
it may be dirt,
but it's classic dirt
__________________
Twin '85 TCs
White/ Grey 2-tone
hmm, could there be another purpose here?
Something besides weight loss?
__________________
Twin '85 TCs
White/ Grey 2-tone
one more thing
Thishiznit the floor as the rear bumper came off the car.
Was Ford using punch cards at the time?
__________________
Twin '85 TCs
White/ Grey 2-tone
