Topic: Snowflakes (Read 2049 times) previous topic - next topic
Snowflakes
I'm looking at running  the flakes for another year. Whats the widest tire I can put on them? I believe there a 16x7 wheel. For some reason the front tires look brand new but the rears are smooth if you look close you can see where the tread used to be. :burnout:
Snowflakes
Aspect ratio will affect total width choice.  Personally, I wouldn't go past 245.
__________________
Twin '85 TCs
White/ Grey 2-tone
Snowflakes
What does Aspect ratio mean?
Snowflakes
Quote from: thewestie;352945
The height of the sidewall (the "50" or "60", etc)
I agree with the above, no wider than a 245.  I've run 245/50's on 16x7's before, and they were OK.  They were also V or Z-rated as well, to cut down on the sidewall squirm.  I HATE squirmy tires.
Snowflakes
Ohh.That's the size i was I was looking at, in a z rated radial and a drag radial
Thanks
Snowflakes
I run 245/50's on 16in snowflakes also
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Snowflakes
I run 225/55/16s on my Snowflakes. The car can burn them at will though.....
Snowflakes
Scored a set of 17x9 wheel from a buddy. If I can come up with the coin id like to get as wide a tire as i can. I want to try and hook this thing up a little
