Topic: Column Shift Quest! (Read 1969 times) previous topic - next topic
Column Shift Quest!
Was going to replace my column shift  with  a custom but never done it before and cant figure how to get it off . Just know its on tight . Should it screw off some way?Or is there some trick?Checked for allen wrench screws or anything but didnt see any.Im afraid i will break it with my luck.Appreciate any tips.Thanks
Re: Column Shift Quest!
From the old site:
88Birdman38
(4/17/03 7:30 pm)
 Hey Eric, everyone.
How in the blazes do you remove the plastic  from the column shifter?? I Want to replace just the , not the entire shaft. I found a nice plain Billet  that will look good in the car, but I cant get the stupid  off!! Any Ideas short of a Sawzall?? hehe
EricCoolCats
(4/19/03 9:24 am)
 Honestly I don't know if it comes off separately; I've never had one come off, anyway. Looks like if you twist really frickin' hard it may...but again, I'm not sure if that'll do anything.
jkirchman
(4/21/03 11:01 am)
 Since you are going to be replacing the  anyway you could get a Dremel ahold of it and cut that sucker off of there. Just cut it away from the shaft. I don't think it comes off as a separate piece either. It did at one time but I think that sucker is glued on there.
TBird232ci
(4/24/03 9:03 am)
 i remember Brians shift  actually broke in half the first day he had his cougar, ill have to ask him if its threaded or not
tbirdpwr
(5/30/03 3:34 pm)
 They have splines,they're just pressed on really hard.
Well got it off ...Man what a job.Thanks for the tips.
