Topic: 87-88 non-TC Lights (Read 915 times) previous topic - next topic
87-88 non-TC Lights
Need all the lights for my 87 T-bird. Looking for a set of headlights that still has good reflectors.
The #@(& PO of my car decided to black out all the other lights with black spray paint, so I need those also. Need taillights, front markers and turns.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
87-88 non-TC Lights
I've got some.
87-88 non-TC Lights
FWIW, if it helps in your search, the 87/88 TC and non-TC lights are all the same except for the inner marker lights, the ones by the header panel. If you end up with some that aren't as nice as you'd like, be sure to check out:
http://www.shinylenses.com
1987 Turbo Coupe - Son's car
1934 Ford - My project car
