Topic: 87-88 TC front A-arms (Read 807 times) previous topic - next topic
Title says it all I need both sides bushings and ball joints can be bad I just need the stampings
email to 2gnrt@comcast.net preferably
Mine came from a '99 SN'95 Stang. They are basically the same part,you just have to install the Thunderbird ball joint. They can be had super cheap,and the bushings are usually better than the older used parts from our cars.
If they are the same an motorsport sells 03 cobra a arms with ball joints for 150
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
The 94-04 Mustang arms are dimensionally the same as the 87-88 TBird ones.  The bushings are different, however, as are the ball joints, but you said you weren't worried about the ball joints.
Speaking of 94-04 arms.  I may have a pair, w/o ball-joints, in the garage.  If you're interested.
