Topic: Water Pump Noise (Read 1967 times) previous topic - next topic
Water Pump Noise
So once and a while my water pump makes a noise, not really a grinding noise but sort of like a "whine". Now it's 99% of the time when the engine is stone cold. Yesterday in the snowstorm home, it made it on and off a couple of times while accelerating close to the shift points of the AOD. Today on the way to work, I did not hear it at all. Does this mean the pump is on the way out and I should replace it, or is this normal? I know my power steering pump whines in a similar sound, but that is "what Ford power steering pumps do".  I sprayed some penetrating oil at the pulley/water pump and the noise changed/went away, so I know it's the pump.
Pump works fine, I checked it for leaks last night and I took the belt off, there does not appear to be any play in the shaft. Just curious, I would rather not replace it at the moment in a snow storm, should I not have to.
Water Pump Noise
I'd use it as is for now,and when the weather allows,swap it. Not that big of a job,and can save a lot of headaches down the road.
Water Pump Noise
Quote from: vinnietbird;351559
+1
Water Pump Noise
Alright. Sounds good. You guys have good luck with the stock replacements available at autozone or CAP?
Water Pump Noise
Quote from: jpc647;351561
Yes sir
Water Pump Noise
Want a Motorcraft pump for less than $50? Order a FRPP replacement pump: http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=3223 I have one on my car and it's just a factory replacement Motorcraft pump with a FRPP sticker over the Motorcraft sticker on the box.
Water Pump Noise
That's what I'm running and no problem. Call fortes in Framingham he had some takeoffs for even cheaper
Water Pump Noise
Quote from: thunderjet302;351634
How can a brand new pump come without a warranty?
Quote from: thewestie;351650
Takeoffs, meaning like "off-brands"?
Also, the ones at the parts store list a normal and a heavy duty application. The HD is twice as much money, is it just a longer lasting pump or is it actually more flow, etc. I may sound stupid asking this, but I went through hell (can I say that?) trying to find the right water pump for my 1972 Olds. I know it's not a big job, but I don't want to have to do it again in a year, lol. Or worse, buy a pump and have it not fit.
Water Pump Noise
Quote from: jpc647;351688
 The HD pumps have a beefier impeller  externally they are identical .
Water Pump Noise
"take offs" He had brand new motorsport crate engines and disassembled them. I bought a set of motorsport heads and pump from one and have a pump on my pick up.
Water Pump Noise
oh. I gotcha, lol. Haha. Thanks for that Steve. Let me know when you are free to look at the dash. I sent you an email a few days back.
