Topic: F/S: 94-98 SN95 Mustang Stock Rear Axles with ABS Exciter Rings (Read 712 times) previous topic - next topic
I have a stock set of rear axles (28 spline) that are out of a 95 GT with ABS reluctor (exciter) rings (5-lug) - $50 plus shipping to any of the lower 48 states via UPS.  These axles measure 30" long and should fit most TC rear ends.  I have more pictures if someone would like them just PM me your email address.
Darren
how much is shipping to 61073 also what rear discs would I use, mark vii? for a TC rear? thanks
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
As far as I know you would need to swap over to the SN95 rear disc brake setup.  These are dime a dozen in the recycle yards as the V6 & GT setups are the same.  Really the only thing you will need is the brackets that attach to the axle tube and caliper bracket, the caliper bracket, and the caliper itself.  I guessed a weight of 30 lbs for the shipping and UPS cam back with about $25 so the total would be $75.
Darren
