Topic: Wiring plug(any cars being parted out) (Read 935 times) previous topic - next topic
http://www.foxtbirdcougarforums.com/showthread.php?30541-AC-clutch-harness-amp-random-plug
Check out the second pic in that post. These are like weatherpack connectors in that you can repin a new connector. These plugs are on the body harness just below the starter solenoid. I think there are more than one 6 position plugs. Id like to get more than one, but i NEED one. Text me with price if you can cut one out of a car you are parting. Ill repin, you can just cut the wires.
713-894-4846 (houston, tx)
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
Will this work
Probably not, Id have to see the pins. These are pretty thick. 4 of the 5 wires look to be 12 guage. They are on the ignition circuit, so pretty heavy.
87 Thunderbird LX
This was from a rear view mirror switch from our cars , If that info helps :)
I cant see a pic?
87 Thunderbird LX
can you post a pic of the plug you are needing?  there are a few different types of pins that were used.
This is one that looks just about identical. I do not know for sure if the original kicked out on both sides, or just one because that part crumbled away. This plug is....$100
Im going to go look at a Mustang today to try to snag one.
87 Thunderbird LX
LOL!!  $100 thats insane...  I bet I have something similar to that I can spare or come up with atleast half of one if you cant get one from the mustang.
Yeah, I about spit coffee on my monitor when the guy told me a hundred bones for one plug.
I just picked up two sets of these from the shack.
http://www.radioshack.com/product/index.jsp?productId=2103449
The fifth wire is the trigger wire for the solenoid, so I can just solder that one. Im thinking I can just squirt some rtv in the back of each plug after I pin it, then electrical tape the heck out of it since these aren't really weather resistant.
Looking at it last night, I think I can cut the harness back and get enough extra wire to make this work.
87 Thunderbird LX
Let me know if you still need the plug.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
THat's the plug for the fusible links in the charging system.  I hard-wired mine in after my plug went kablooey.
