Topic: drag tires? (Read 4011 times) previous topic - next topic
drag tires?
i found a set of nitto nt555 on white pony wheels on craigslist they look to be pretty wore but they should have a few passes on them. the guy wants 75 is it worth it? i always wanted to run my car down the strip but never had the chance and i was wondering if these would be better then my bfg radial t/a's on the strip?
drag tires?
The NT555 are better than regular street tires, but if you need something to hook, save the $75 and wait for a set of MT Drag Radails, it'll be more money but far better spent!
I use the NT555's for the street.  They are far safer than regular street tires (less tendency to go sideways on a power shift).  Track use not so much.  If I go to the track, I swap to the MT DR's.  They are an incredible track tire.
drag tires?
i found a pair of slicks there on 10 hole wheels and he wants 200 i dont have that much power but it dose have enought to kick it sideway from a dead stop
drag tires?
Keep in mind that running slicks requires long studs and a driveshaft loop
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
drag tires?
oh ok i didnt know that thanks i might just go with the nt555 and if they dont make it to the track ill tkae them with me in may to ocean city for crusing weekend and burn them off
drag tires?
ET streets and Quick time pros work very well.
drag tires?
ok thanks
drag tires?
I use to run 28 by 10.5 on stock 10 holes with no probs on my 85
Here is a good pic of how well they fit.
drag tires?
ok well my car is an 87 and i have a mustang 8.8 in so with the right wheel i can get a little fatter tire in there
drag tires?
28/10.5 is about as big as you can go.
I run 28/11.5 on my wifes 85 stang
drag tires?
Aren't the Quick Time Pros a bias-ply?
drag tires?
Quote from: V8Demon;351063
Yeah and a bitch to drive on if you get caught in the rain.
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
drag tires?
Do you run bias ply tires up fron as well?  I've been advised that mis-matching them with a radial is a no-no....
drag tires?
Quote from: V8Demon;351074
Ive run both bias and radials on the front with the quick time pros.  The radials handle a whole lot better on the street.  The car sees limited street time (less than 500 miles a year) so im not super worried.  Also, its pretty much a drag car with an inspection sticker.:mullet:
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
drag tires?
It can be a pretty scary ride when they're mixed!  The dramatic difference in side wall stiffness (or lack thereof for the bias ply) can lead to control issues.
